With that width and offset and only 265's I wouldn't think you would have many rubbing issues in the rear. If you are rubbing just slightly you may be able to get away with running a little more negative camber if you dont want to roll the fenders.
Check to make sure that the nuts on top of the coilovers are tight...use an impact gun.
