TwinTurbo.NET: Nissan 300ZX forum - Also, do not forget that the 5-link rear suspension system
Subject Also, do not forget that the 5-link rear suspension system
Posted by Ash's Z on January 30, 2010 at 11:59 PM
  This message has been viewed 278 times.
In Reply To To delete Hicas or not to delete? That is the question. posted by LivinTheDream on January 29, 2010 at 11:00 PM
Message in our vehicles already produces toe-in during a turn.
The geometry of the rear suspension produces toe-in through a turn as the suspension compresses on the outside wheels. This produces a very smooth and predictable reaction to the yaw of the vehicle during a turn. Additionally, the quicker the turn-in you create at the steering wheel, the greater the roll of the body will be, thereby producing an even greater toe-in on the outer wheel which improves the stability of the vehicle. The HICAS system essentially enahnces this same effect by way of creating additional yaw to both of the rear wheels. However, because the system's control algorythms are based both on speed and steering wheel position, and also including a time-based reaction sequence, it creates a chassis response that virtually requires your brain to incorporate real-time computational dynamics of its own to properly coordinate steering wheel input that produces the desired effect.
It was a nice try, but leaves a lot to be desired....
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
