TwinTurbo.NET: Nissan 300ZX forum - I had the same problem. replace cluster first.
Subject I had the same problem. replace cluster first.
Posted by tuckz32 on January 29, 2010 at 6:43 AM
  This message has been viewed 178 times.
In Reply To oil pressure? posted by Pahaf on January 29, 2010 at 02:38 AM
Message I had two major problems that came from a bad speedometer/cluster.
1. power steering would go in and out. Going around a curve at speed would almost cause an accident by causing the car to swerve in the other lane.
2. While pushing the clutch in at moderate speed would cause the engine speed to drop and the car would CUT OFF.
3. After changing the cluster those problems disappeared. the speedo was defective...
