TwinTurbo.NET: Nissan 300ZX forum - crankshaft oiling has nothing to do with crank failure IMHO
Subject crankshaft oiling has nothing to do with crank failure IMHO
Posted by aliaZ on January 17, 2010 at 2:14 PM
  This message has been viewed 296 times.
In Reply To VG crankshaft oiling = broken crank? posted by LitlElvis on January 17, 2010 at 01:16 PM
Message the pics posted thus far show fatigue failure, and show very little bearing damage that would be caused by lubrication problems.
I think it is a harmonic issue caused by not running a dampened pulley. I've talked to Crower about this issue, and they believe that not running a dampener may be a huge contributing factor, if not the sole reason, for crank failure at the 1k RWHP level.
Are you sure your illustration of the domestic v-8 cross drilled oiling system is correct? Reher Morrison says that the rod feed hole intersects at the centerline of the crank, not how you show it.
[ http://www.rehermorrison.com/blog/?p=214 ]
