TwinTurbo.NET: Nissan 300ZX forum - I found a test which said PS fluid-acetone works even better
Subject I found a test which said PS fluid-acetone works even better
Posted by Whatsthegoodword on July 12, 2009 at 1:16 PM
  This message has been viewed 89 times.
In Reply To If you have stuck bolts try this!! Hope its not a repost posted by texasfan1528(MO) on July 12, 2009 at 11:16 AM
Message Most sites pass on incorrect info though, I believe it was actually done with pins and PS fluid, not bolts and ATF. Here is what I found: how to loosen stuck bolt I still prefer PB Blaster because it comes in a spray can - otherwise you will have oil dripping all over the place.
_________________________________
http://www.myturbodiesel.com, the VW TDI diesel technical forum and FAQ
50+ mpg and 1200 miles per fill up
