TwinTurbo.NET: Nissan 300ZX forum - Remove Radiator, Fan Blade, Old Pulleys, Belts
Subject Remove Radiator, Fan Blade, Old Pulleys, Belts
Posted by Trailboss on June 24, 2009 at 8:39 AM
  This message has been viewed 1338 times.
In Reply To Gauging cost for UR water pump pulley install w/ all 3 belts posted by Turbonium 300Zx on June 23, 2009 at 07:32 PM
Message Then re-install all, including re-fill the radiator.
The crank pulley is the hardest. If you have an automatic, you will have to drop the starter motor and block the flywheel to remove and reinstall crank bolt.
I'm guessing anywhere from 4-6 hours. I did it myself. Figure around $100-$125/ hour.
