TwinTurbo.NET: Nissan 300ZX forum - Actually when I was cleaning my engine with seafoam
SlowZ(SD)
on June 23, 2009 at 1:04 PM
WD40 VS PB Blaster?
posted by Sound Creations (OK)
on June 23, 2009 at 11:43 AM
I saw the seafoam dripping through some vacuum lines. That’s how I found some of my air leaks
WD40 VS PB Blaster?
11:43:07 06/23/09
What method are you using to find the leak?
kenecchi
11:48:51 06/23/09
if your trying to find a leak...
dirtyjerZ
12:08:30 06/23/09
Soapy water. (n/m)
12:45:02 06/23/09
if it's under vaccum (idle) then how does it make bubbles?
LordZ
17:54:55 06/24/09
Actually when I was cleaning my engine with seafoam -
SlowZ(SD)
13:04:23 06/23/09
Brake parts cleaner doesn't leave a residue
canyoncarver
14:15:58 06/23/09
Are you pressurizing the system first?
LordZ
15:20:16 06/23/09
+1 for Soapy water (n/m)
Cuis-Z
18:19:15 06/23/09
Thanks for the Input
19:32:43 06/23/09
I believe Bobby from the Z club has the equipment to fog
21:49:09 06/23/09
I personally wouldn't use wd40 or pb-blaster...
LordZ
17:57:25 06/24/09
