TwinTurbo.NET: Nissan 300ZX forum - If at all possible, replace the EFI harness.
Subject If at all possible, replace the EFI harness.
Posted by kkrofft (OH) on January 01, 2009 at 10:16 PM
  This message has been viewed 80 times.
In Reply To Re: I bought my clip from Noyan USA. They treated me well. posted by 3zMc on January 01, 2009 at 07:23 PM
Message Think about it this way, your harness is now around 14 years old. Most likely it has many corroded connectors. If you don't replace it you will end up chasing electrical issues that have nothing to do with the swap but you won't know for sure. So unless it has really clean and shiny contacts, don't consider reusing it.
The JDM harness won't fit. Also, your '95 uses a slightly different setup than the clip you will likely find. You will want to use the ECU from the clip and the older ECU's are easier to tune so a new old style harness is perfect.
I think my clip was $3300 delivered. The rod bearings were worn a bit more than I thought was acceptable so Noyan paid me for the replacement bearings.
KK
