TwinTurbo.NET: Nissan 300ZX forum - Don't have to remove the abs sensors or sway bar
spyhunterTT(nj)
on December 21, 2008 at 8:27 AM
Differential removed and ready for Leader Gears.
posted by PiotrC70
on December 20, 2008 at 12:39 PM
but it's probably easier to do so.
Alex
PiotrC70
12:39:29 12/20/08
I've found reinstalling the trans is the worst part.
en5
16:53:09 12/20/08
Using bolts with heads cut off as guides helps...
gunghoe9
17:00:36 12/20/08
timing belt idler studs also work well as guide pins (n/m)
aliaZ
18:05:10 12/20/08
Do it few times and it becomes easy :) (n/m)
Piranha(AZ)
17:18:42 12/20/08
No kidding! Pirahna witnessed my pattented 92 minute trans
nemo1080 (Iowa)
18:32:21 12/20/08
I thought they were discontinued?
BannonZ
18:32:47 12/20/08
they're not discontinued per Mark Leader (n/m)
aliaZ
18:46:53 12/20/08
just through SZ? (n/m)
BannonZ
18:48:31 12/20/08
SZ is the sole distributor
aliaZ
18:53:19 12/20/08
thought I saw a post here the other day, where Seb
BannonZ
19:01:27 12/20/08
Mark Leader responded to that same post (n/m)
aliaZ
19:27:16 12/20/08
You're correct.
PiotrC70
19:29:47 12/20/08
no
aliaZ
19:39:28 12/20/08
I could be misreading Marks reply as well, but in his post
PiotrC70
20:28:17 12/20/08
I love the gears, but they're a tad noisy
aliaZ
23:26:11 12/20/08
Is your gear noise at all speeds, or mainly betw. 60-70mph?
TTkeeper
11:00:02 12/21/08
mainly 60-70 mph
aliaZ
12:08:01 12/21/08
special order = 1 off sets. That will not happen. (n/m)
01:41:02 12/21/08
I have a set new in box if anyone is looking. (n/m)
01:39:03 12/21/08
Don't have to remove the abs sensors or sway bar -
spyhunterTT(nj)
08:27:45 12/21/08
