TwinTurbo.NET: Nissan 300ZX forum - Piston condition will affect oil pressure if enough oil
Subject Piston condition will affect oil pressure if enough oil
Posted by The Devils Z on December 21, 2008 at 7:15 AM
  This message has been viewed 98 times.
In Reply To Piston condition can't effect oil pressure. Oil on the posted by kkrofft (OH) on December 20, 2008 at 09:39 PM
Message gets past the piston into the intake / combustion process enough to create a low oil level condition.
If the oil level is low - it can cause a low oil pressure situation.
You are correct that smoke (usually blue) is seen in the exhaust under load and that usually this is is the sign for turbo seals ..
=============Sig begins here================
The Devils Z.com
The Devils Z Pic
666 rwhp dyno
The Demon Z pic (in progress)
View Me! Disclaimer : Not Safe For Work !
