TwinTurbo.NET: Nissan 300ZX forum - Piston condition can't effect oil pressure. Oil on the
Subject Piston condition can't effect oil pressure. Oil on the
Posted by kkrofft (OH) on December 20, 2008 at 9:39 PM
  This message has been viewed 93 times.
In Reply To Simple... I can't posted by The Devils Z on December 20, 2008 at 09:17 PM
Message cylinder walls is sprayed there. By the time it is on the wall it has left the pressurized part of the system. The oil in the intake would result from a broken land if it allows the cylinder pressure past the rings pressurizing the crankcase causing the oil to blow out the pcv system into the intake.
Normally a broken ring land will cause smoke when the oil gets into the combustion chamber and goes out the exhaust.
I question JWT's assesment based on the facts provided. Number one cause of oil in the intake would be leaky turbo seals. Or maybe a bad valve seal. But I have it on good authority that the VG's seals do not fail often.
KK
