TwinTurbo.NET: Nissan 300ZX forum - 4th, and don't mess with replacing the radiator to run it.
TriniTT
on December 06, 2008 at 7:00 PM
Get a new tensioner.
posted by ZXRider(SoCal)
on December 06, 2008 at 04:02 PM
It'll do fine just starting it up and running for a few seconds to verify damage or not. That'll save you a little bit of time at least.
Cheers,
JBrobst
engine carnage guestimates...
AntiHero
14:35:08 12/06/08
Explain what you mean by "died."
treese88
14:41:57 12/06/08
lost power. "Stalled and now wont start"
AntiHero
14:46:31 12/06/08
Re: lost power. "Stalled and now wont start"
Seb (specialty-Z)
15:22:43 12/06/08
uhhh? wrong post? (n/m)
AntiHero
15:31:07 12/06/08
just saying it could have overheated.
Seb (specialty-Z)
15:37:32 12/06/08
huh?
AntiHero
15:40:17 12/06/08
maybe overheats till the crank or cams seize? (n/m)
AntiHero
15:42:38 12/06/08
nope (n/m)
Drk93TT
15:51:16 12/06/08
check your CAS connection. (n/m)
nemo1080 (Iowa)
15:45:47 12/06/08
cas is fine
AntiHero
15:47:57 12/06/08
that does suck. good luck man! (n/m)
nemo1080 (Iowa)
23:27:50 12/06/08
clarification...
AntiHero
15:50:00 12/06/08
tensioner failed (n/m)
Guapo
15:51:02 12/06/08
would you bother with a timing belt job?
AntiHero
15:53:04 12/06/08
ZXRider(SoCal)
16:02:25 12/06/08
Re: Get a new tensioner.
txq45
16:07:41 12/06/08
Third (n/m)
Gordo 93TT Daytona
16:37:46 12/06/08
4th, and don't mess with replacing the radiator to run it. -
TriniTT
19:00:17 12/06/08
and/or the center idler pulley stud. (n/m)
zfreak(Dallas)
17:40:17 12/06/08
That wouldn't cause the belt to be loose. (n/m)
TriniTT
18:59:11 12/06/08
yes it would
spyhunterTT(nj)
07:59:49 12/07/08
oh yeah.. :) true. (n/m)
zfreak(Dallas)
09:46:21 12/07/08
120K kit since its unknown age. lmk when you wanna do it. (n/m)
ZiNnYc
01:08:22 12/07/08
a leak down test will tell you if your valves are bent (n/m)
aliaZ
16:46:50 12/06/08
It seems surprising that someone who's been here
canyoncarver
09:43:06 12/07/08
Pull your plenum and look down into your heads to see if a
amp300zx
11:17:27 12/07/08
calculated risk.
AntiHero
14:30:57 12/07/08
