TwinTurbo.NET: Nissan 300ZX forum - ES rear differential bushing install advise
Subject ES rear differential bushing install advise
Posted by RICH1 on November 29, 2008 at 9:35 AM
  This message has been viewed 2055 times.
Message Ok so far my Thanksgiving weekend project has been going pretty good but now I need some advice. I decided to drop the differential and do the complete bushing replacement instead of just the two front bushings. I have all the old bushings out, including the oter metal sleeves from the origional bushings in the subframe (note: the subframe was not removed). The anoying problem is getting the rear ES subframe bushings installed. I am using the 1/2 threaded rod method suggested in Mike Smith's writeup but as soon as I start getting some pressure on the bushing it wants to shift and wont start in the hole. I thought I ran across a post from Damon where he placed the inner metal cup in the ES bushing to keep it from shifting. I am also trying to use one of the front bushing to pull the rear bushing in and if I use the metal cup it seems like that will keep the ES bushing from shifting. Does this method look viable or does anyone have any advice before I waste an entire day
in frustraion?
Origional front mount bushing size compared to the OD of the ES rear bushing
I still need to burn off the rest of the rubber from the metal cup
