TwinTurbo.NET: Nissan 300ZX forum - Replace the rear crank seal. Check egr valve operation>>
Subject Replace the rear crank seal. Check egr valve operation>>
Posted by ZUL8TR on November 15, 2008 at 6:23 AM
  This message has been viewed 134 times.
In Reply To Tranny out, what next? posted by CatchingZs on November 15, 2008 at 04:28 AM
Message and fix if needed. O2's easier to service if they test defective. Inspect the drive shaft universal joints and the center suport bearing replace if needed. The stock 2 piece DS does not allow the universal joints to be replaced. Replace the tranny rear isolater mount they sag with age. Inspect the slave cylindere for leaks and fix if needed.
Verify the clutch part numbers from your jobber. Are you doing a stock clutch?
Also replace the piolet bushing and throwout bearing and inspect the flywheel and surface if needed. Make sure all surfaces that the clutch contacts are clean.
ZUL8TR in Orlando,FL
