TwinTurbo.NET: Nissan 300ZX forum - High mileage NA, need advice
Subject High mileage NA, need advice
Posted by gjohnson25 on October 23, 2008 at 10:37 AM
  This message has been viewed 124 times.
Message Own a 93 NA 2+2 Auto, completely stock with 180,000 miles. Plan on doing an engine/tranny swap in the next few years, but I need the car to last that long. A lot of the OEM parts are starting to wear out. What would be the best things to replace, to work on, etc...?
I've replaced/added the following over the past 2 years:
•STARTER
•ALTERNATOR
•A/C COMPRESSOR
•POWER STEERING PUMP
•ENERGY SUSPENSION STEERING RACK BUSHINGS
•NISMO TRANSMISSION MOUNT
•300 DEGREE EGR BYPASS KIT
•STRUTS
•BRAKE PADS
•OIL PRESSURE SENDING UNIT
•BATTERY
•A/C VALVE ADAPTERS
•SPARK PLUGS
•FUEL FILTER
•ALTERNATOR ASSEMBLY
•POWER STEERING DRIVE BELT
•ALTERNATOR DRIVE BELT
•A/C COMPRESSOR DRIVE BELT
•AAC (IACV) & AIR REGULATOR CONNECTOR (BLUE)
•IGNITION COIL PACK CONNECTORS
•KNOCK SENSOR HARNESS
•TWIN TURBO TAILLIGHT SENSOR
•TEMP SENSOR CONNECTOR (YELLOW)
•A/C RELAY
•DRAIN PLUG & WASHER
•A/C COMPRESSOR IDLER PULLEY
•REAR MAIN SEAL
•REAR RETAINER GASKET
•REAR OIL PAN SEAL
•KNOCK SENSOR
•OXYGEN (02) SENSORS
•FRONT INNER TIE ROD (PASSENGER)
•POWER STEERING RACK BOOT (PASSENGER)
•IGNITION COIL PACKS
•ABS RELAY VALVE ASSEMBLY
•ABS RELAY ACTUATOR ASSEMBLY
