TwinTurbo.NET: Nissan 300ZX forum - you should at least fix the system and monitor it using an
Subject you should at least fix the system and monitor it using an
Posted by gt300zxtt on September 14, 2008 at 10:09 AM
  This message has been viewed 78 times.
In Reply To Just a direct circut from something that turns on and off posted by Sleeper_TTZ(SeKy) on September 14, 2008 at 05:39 AM
Message electrical fuel pressure gauge. not only does that sound like a bandaid, i think it may cause more problems at idle at the very least. basically, the injectors have very little need. with the stock setup, the ecu knows that and sends little voltage and thus less flow so that the regulator can regulate within its means. however, if the pump is at max blast when there is no need, there is nothing to say it is actually within the means of the regulator.
