TwinTurbo.NET: Nissan 300ZX forum - I also dont see how two high-tension valve springs acting
Subject I also dont see how two high-tension valve springs acting
Posted by Ash's Z on September 08, 2008 at 11:16 PM
  This message has been viewed 595 times.
In Reply To Brett, Q about your plot and the paragraph below it: posted by Ash's Z on September 08, 2008 at 10:33 PM
Message on the camshaft lobe of such small diameter can produce the amount of torque it required for me to make this VTC here on the bench over-rotate.
I just tested to see what kind of torque it requires on the camshaft to rotate it to lobe peak and it takes 18ft/lbs as indicated with my torque wrench on the VTC retaining bolt with the JWT high tension springs and JWT 500 series camshafts.
I also rotated the camshaft/VTC sprocket to the position of e maximum torque in the closing event produced by the cam/valvesprings (18-ft/lbs) using the torque wrench and then locked the VTC by the outer sprocket. The cam helix did not rotate at all from its stop. While still locked in this position, I tapped the front VTC retiaining bolt to see if the piston helix would slip, and it doesn't.
I dont know if you have performned these tests yourself or not, but what I am seeing here is clear evidence that the VTC is not overrotating at all - there simply isn't enough torque from the camshaft/valvesprings nor is there any shock in the system that could break that anti-lash of the helix loose - even if there were, there still isn't sufficient torque from the cam to overpower the piston helix return spring and cause the piston to move up off its stop....
I dunno Brett, but what I'm seeing here is telling me that my running test I described to you in email earlier today is going to yield the same results - the camshaft/valvesprings simply isn't overpowering the VTC mechanism and causing the cam to overrotate.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
