TwinTurbo.NET: Nissan 300ZX forum - Re: How does a water pump die?
Subject Re: How does a water pump die?
Posted by Stadsport on August 27, 2008 at 12:55 PM
  This message has been viewed 83 times.
In Reply To How does a water pump die? posted by MrPulldown on August 27, 2008 at 12:34 PM
Message Did you check out the overflow bottle and all? It's possible your cap is shot and there's a leak related to the overflow container, causing water to leak out through that.
Water pumps generally either have a slow drip (I know the Z31 had a "weep hole" to check for leaks) or catastrophically fly apart (see: ex's 95 Jeep Wrangler).
Also, did you investigate while it was cold or hot?
