TwinTurbo.NET: Nissan 300ZX forum - How does a water pump die?
Subject How does a water pump die?
Posted by MrPulldown on August 27, 2008 at 12:34 PM
  This message has been viewed 151 times.
Message I have a leak come from the bottom of the engine behind the crank pulley. Fill the radiator and it will leak. After a day or two it will stop. Engine doesn't over heat.
Last night I tore into to investigate. No leaks coming from rad or any of its lines. Pulled rad, hard lines, upper T-belt covers. No leak coming from the two small bypass hoses. Kindda hard to tell but don't think the hardlines/block interface is leaking. T-stat not leaking.
Didn't get the lower T-belt cover off, but something is still leaking. The pool above the water pump, behind the hardline was full last night, and empty this morning. Seems like the leak is coming from behind the lower T-belt cover.
What gives.
