TwinTurbo.NET: Nissan 300ZX forum - Re: Time to "upgrade" the garage...need advice
Subject Re: Time to "upgrade" the garage...need advice
Posted by outkaZTT on August 21, 2008 at 3:50 PM
  This message has been viewed 101 times.
In Reply To Time to "upgrade" the garage...need advice posted by Madhatter10-6 on August 21, 2008 at 01:30 PM
Message Sherwin Williams Armorseal 1000 is a nice 2 part epoxy floor coating. I would suggest 2 things if you work in your garage
1: Use a product called "Sharks Grip" in the epoxy. It will provide grip when the floor gets wet.
2: Dont do the color flakes on the floor if you work on your car. Drop a washer or small clip and you'll be there all day trying to find it.
If you have a contractor do the floor make sure to ask them about their prep. At the very least they should acid etch and power wash it. Using a floor sander to scuff it is also something to look for. My company charges $4/square foot to do the color flake with clear sealer and about $3 to do a solid color 2 part epoxy. Obviously prices vary per location but just to give you an idea.
Good luck
