TwinTurbo.NET: Nissan 300ZX forum - Nice time to replace the clutch MC or make a pedal
Subject Nice time to replace the clutch MC or make a pedal
Posted by jzack on July 31, 2008 at 7:00 PM
  This message has been viewed 91 times.
In Reply To things to do while the dash is off posted by jkeyser14 on July 31, 2008 at 06:50 PM
Message adjustment - everything is easy to reach.
- Good chance to make some extra wire runs for adding things later
- While I had the heater box out, I used some white grease on all the various actuators and links for the air flap doors.
- Do a good job cleaning up the air box from any residual leaked coolant. It will still smell after the job is done.
- Be sure to add a ground wire to the rear bolt that holds the heater core pipes in place (rear of air box). Ground the wire to some convenient body point - this will greatly reduce electrolysis in the pipes and core.
- Fix (glue) the dash if it's peeling up by the defroster vents
I hated doing this core replace job - takes forever to get everything apart and then back together.
