TwinTurbo.NET: Nissan 300ZX forum - yup...the knock sensor trying to control things. (n/m)
zfreak(Dallas)
on July 24, 2008 at 9:29 PM
Well the combination of 13:1 A/F and
posted by Kyle(Houston)
on July 24, 2008 at 01:45 PM
Went to the dyno this morning...
Bama Z
12:32:25 07/24/08
You need to get it checked...running lean and detonating... (n/m)
Kyle(Houston)
12:40:38 07/24/08
How can you tell it's detonating? I need to learn how to
Evan3zx(ca)
13:21:23 07/24/08
Kyle(Houston)
13:45:02 07/24/08
yup...the knock sensor trying to control things. (n/m) -
zfreak(Dallas)
21:29:24 07/24/08
Looks like Bama Z will be Blown Z if you don't get that
Scotts94z32
12:52:14 07/24/08
what is ideal? (n/m)
moxie (SF)
13:02:04 07/24/08
11.5:1 (n/m)
MixManMash
13:07:02 07/24/08
is that specific for the Z32?, or across the board? (n/m)
moxie (SF)
13:09:05 07/24/08
I would suspect it's the same for most Turbo Cars.
MixManMash
13:11:20 07/24/08
Are you sure that's not compression ratio? (n/m)
TriniTT
15:06:40 07/24/08
Yes. "Air-cooled" is the key word. (n/m)
MixManMash
15:40:26 07/24/08
pump gas, compression, and turbo related
gt300zxtt
13:20:28 07/24/08
VW's run low 13's for AFR stock... scary (80 (n/m)
1badz32 (MN)
15:49:45 07/24/08
Depends if they are Direct Injection or not. I believe the
MixManMash
18:29:03 07/24/08
My buddies '00 TT (1.8T) ran low 13's AFR stock.
1badz32 (MN)
07:03:41 07/25/08
general. (n/m)
Inzane
16:14:02 07/24/08
I told you mang ;)
TriniTT
12:59:10 07/24/08
not only that
gt300zxtt
13:16:50 07/24/08
If I'm not mistaken the TT ECU will run the TT fuel pump
SlicktopTT
13:19:14 07/24/08
the gotcha is the fuel pump controller.
Guapo
13:29:38 07/24/08
Right, and as Guapo's link mentions, it can compromise
TriniTT
14:21:52 07/24/08
fwiw, mine is still running strong after 5 years.
Guapo
14:37:24 07/24/08
I don't think it compromises the life of the pump at all.
SlicktopTT
14:50:54 07/24/08
Not to be a smartass..
SeanK (StL)
16:34:51 07/24/08
That's interesting. Mine was really loud, louder than road
TriniTT
15:06:01 07/24/08
uhh no problems here on the fuel pump (n/m)
spyhunterTT(nj)
19:21:42 07/24/08
Hi cory im corey. nice Z and not bad numbers!
z-spott[HI]
16:55:39 07/24/08
