TwinTurbo.NET: Nissan 300ZX forum - If I'm not mistaken the TT ECU will run the TT fuel pump
Subject If I'm not mistaken the TT ECU will run the TT fuel pump
Posted by SlicktopTT on July 24, 2008 at 1:19 PM
  This message has been viewed 128 times.
In Reply To I told you mang ;) posted by TriniTT on July 24, 2008 at 12:59 PM
Message at 3 voltage stages. Don't recall the actual voltage levels off the top of my head but let's just say "low" for idle, "mid" for cruising and full 12 volts for wide open throttle.
NA ECU only runs low and full, therefore the NA ECU should run the TT fuel pump at full voltage creating the "buzz" many refer to. NA ECU running a TT fuel pump at full voltage should not be a problem.
Someone please correct me if I'm wrong.
