TwinTurbo.NET: Nissan 300ZX forum - Re: Has anyone had any leaks or problems with the 300degree rail
Subject Re: Has anyone had any leaks or problems with the 300degree rail
Posted by Dallas DamonZ on July 22, 2008 at 6:09 PM
  This message has been viewed 81 times.
In Reply To Has anyone had any leaks or problems with the 300degree rail posted by JayT (Tampa,FL) on July 22, 2008 at 01:56 PM
Message :I dont know why they are saying the wont install them?
Sure, people have leaks on installation. AN doesn't spec a torque (even if they did it would be hard to measure in most instances because you can't use sockets on the fittings), so people get a little timid and don't want to strip things by twisting too much. We recommend pressure testing before installation for this reason. You can usually work out problems before committing to buttoning up the installation. Even so, once the kit is installed, it makes it a TON easier to remove the plenum than the OEM setup (even with the SZ line kit) to fix leaks from not getting things snugged down as required the first time.
Like anything else fuel related underhood of the Z32, you'll need to stay vigilant, but the military, FAA, and racecar folks don't run AN fuild line connections because it's prone to failures...
Later
Click here to e-mail me!Click here for Twin Turbo Zs of Dallas!
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut." - Albert Einstein
When was the last time you *really* did something with your Z to call yourself a Z enthusiast?
Member #1 PETZ
