TwinTurbo.NET: Nissan 300ZX forum - Blazt USB connection problem
Subject Blazt USB connection problem
Posted by Broke_as_**** on July 14, 2008 at 11:12 PM
Message Sorry, this should probably be in tech but I can't get my blazt cable to connect to my ECU. It used to work fine and then I tried hooking it up to my Sentra and it hasn't worked on the Z ever since then.
It's on a known working port (as verified by a open port finding utility) and I run the auto search but it doesn't find the ECU. I've tried it with just the ignition on and while running. I've tried cleaning the contacts on both sides of the consult connector.
Do the address read and ECU port id sections have to be filled in with anything in particular? I thought the auto search came up with that.
Again, sorry to post this in General but it would be a huge help to solve this tonight while I'm trying to figure out this fuel pressure issue.
