TwinTurbo.NET: Nissan 300ZX forum - You're probably going to need some help (in person help, not
Subject You're probably going to need some help (in person help, not
Posted by JuleZ on June 04, 2008 at 6:20 PM
  This message has been viewed 114 times.
In Reply To Audio inquires.... posted by WoodmanZ on June 04, 2008 at 05:45 PM
Message just internet help) in order to do this yourself. Yes, you will need an amplifier for the sub. If you are using the amp for the sub only, it needs to be a mono amp or a 2-channel amp that you can bridge to one channel, which means that you're essentially feeding power from two channels into one. The head unit can adequately power the rest of the speakers unless you're looking for something extreme.
As for your question about the vented box, it's a matter of preference, but in my opinion, a single 10-inch sub in a sealed box is plenty for the Z. I have a 10" Infinity Kappa Perfect (several years old) in mine, powered by a Pioneer amp that pushes 150W RMS (if my memory serves correctly), and it sounds great.
Sounds like you're on your way to a nice setup; you just want to make sure it's all installed right. It might be worth spending a little more cash (maybe $80-$100) to take all the gear you've collected to a stereo shop and have it professionally installed.
