TwinTurbo.NET: Nissan 300ZX forum - General question on 300 degree fuel rails
Subject General question on 300 degree fuel rails
Posted by ConVerTT on June 01, 2008 at 8:39 PM
  This message has been viewed 254 times.
Message There is probably an obvious answer to this so I apologize in advance if I am just brain-locked.
Prior to the 300 degree fuel rails, if you wanted to install some pintle-less injectors (like the 740's) into the a 90-93 lower plenum, the seat of the lower plenum needed to be machined so that the injector sat lower in the plenum.
Now with the 300 deg rail, the lower plenum does not get machined, plus there is the thickness of the rail itself. Does this result in the injector tip sitting quite a bit higher in the lower plenum as a result? If so, why is this OK?
Thanks in advance
Pics
Cruizin' Topless on December 26th
Engine Bay Pics
719 miles on the turbo'ed NA 'VerTT and counting
Versus TransAm
Versus Audi S4 Biturbo
Versus Cadillac XLR
NA's are for Sissies
Sudden Loss of Boost is Heartstopping
First Driving Impression
Preliminary Dyno Results
Acknowledgments
