TwinTurbo.NET: Nissan 300ZX forum - Swapped coil pack, no change, swapped plug with #1
Marc (NJ)
on May 30, 2008 at 3:10 PM
Maybe but unlikely - how does the spark plug/coilpack or
posted by Bernie (NoVA)
on May 30, 2008 at 10:34 AM
plug no change but they both looked a little wet. #1 cylinder works fine though. New CAS, new PTU. What else to do? Cylinder #3 worked fine b-4 injector change so I don't think it's compression.
Did any1 install Deatschwerks injectors with their 95- kit ?
Dark Diver
04:17:35 05/30/08
Grinding the 90-94 plenum for #1 when using '95
ThunderZ
06:23:07 05/30/08
You have to grind #1 for clearance ANY time you convert
07:20:14 05/30/08
thus ...
Guapo
08:36:05 05/30/08
Poop, I forgot about that
13:33:07 05/30/08
I hear the 90-94 style Deatschwerks injectors are still
Jason300zxTT
07:48:13 05/30/08
There is no such thing as a 90-94 Deatschwerks injector
Cade(PA)
07:57:00 05/30/08
hmm.. must of read the post wrong.
Jason300zxTT
08:56:10 05/30/08
I think I have a bad one already w/no road time on it....
Marc (NJ)
09:34:07 05/30/08
Check your wire splice. (n/m)
09:49:58 05/30/08
Wire splice is fine, could the injector be stuck? or clogged (n/m)
Marc (NJ)
10:11:25 05/30/08
10:34:48 05/30/08
Swapped coil pack, no change, swapped plug with #1 -
Marc (NJ)
15:10:02 05/30/08
Did you check for spark? If the plug was wet, the
ThunderZ
21:10:22 05/30/08
It could be the connector. Check your wiring. If freshly
Yoshi
13:29:22 05/30/08
it's a kick ass service/product they offer (n/m)
09:34:33 05/30/08
I regret buying deatschwerks
ali300zx
10:24:00 05/30/08
Well buying "resized" stock injectors isn't be best idea
10:36:22 05/30/08
Did Deats replace them? (n/m)
Yoshi
13:30:09 05/30/08
Re: Did Deats replace them?
ali300zx
15:38:02 05/30/08
I know what you mean...I switched to Deats a while
Yoshi
16:22:40 05/30/08
I hope you guys are ALSO doing the 12v injector rewire
16:55:23 05/30/08
FYI -- I've had 5 old style (new) ones installed for 1 year
jzack
17:29:18 05/30/08
yes 740's and i just used a dremel and grinded out the area
pearlyellowtt
08:03:26 05/30/08
OK, thanks guys, that's what we did.
Dark Diver
16:28:34 05/30/08
They rebore stock injectors to get the higher flow rates.
16:57:27 05/30/08
Re: They rebore stock injectors to get the higher flow rates.
ouikikazz
18:00:06 05/30/08
Make your own conclusions...
19:42:30 05/30/08
Re: Make your own conclusions...
ouikikazz
02:17:22 05/31/08
