TwinTurbo.NET: Nissan 300ZX forum - Why a VG engine when there are better options?
Subject Why a VG engine when there are better options?
Posted by inferno on May 25, 2008 at 6:18 PM
  This message has been viewed 819 times.
In Reply To My new project............it will be VG powered! posted by Rob'Z on May 25, 2008 at 05:27 PM
Message This engine, for example, is much more suitable for a lightweight racecar:
______________________________________________________________________________________________________________________________________________________
Following two years of continuous development, the Powertec RP - V8 engine is not only the most powerful
small capacity V8 racing engine, but also the most reliable. All new phase 3 engines are fully warranted for 30 hours
between rebuilds.
The Powertec RP Macroblock engine comprises Suzuki GSXR 1300 cylinder heads mounted to a dedicated dry
sumped crankcase. A flat-plane steel billet crankshaft transmits power to the gearbox, while a gear-driven shaft drives
four scavenge pumps, two oil supply pumps and the water pump.
Now available in 2.6 and 2.8 litres, the RP Macroblock can be supplied in standard or tuned specification with either a
twin-butterfly plenum chamber or eight-butterfly induction system.
Powertec RPA Macroblock V8
Engine Specification
72° V8 cylinder, 32 valve quad cam
Steel flat-plane crankshaft
Twin pump lubrication system
Four scavenge pump dry sump system
Rotary vane coolant pump
Pre-engaged starter motor
Belt driven 45amp alternator
Dimensions
Length: 546mm
Width: 513mm
Height: 440mm
Dry Weight: 88kg (194lb)
Bellhousing/Clutch
Twin-plate dry clutch
Integral oil tank capacity: 9 litre
Integral rear engine mount
Engine-gearbox spacing: 126mm
Dry weight 13.7kg
Powertec RPB – 2.8 Litre, Tuned
Maximum power 430bhp (plenum), 450bhp (8 butterfly)
Maximum torque 250ft lbs
Maximum revs 10,500rpm
Bore 84mm diameter
Stroke 63mm
Compression ratio 13.5:1
source: [ http://www.powertecracing.com/ ]
The newest version of the Powertec engine now displaces 2.8 liters and delivers 455 horsepower. According to Radical, it’s the most powerful small displacement racing engine available. Installed in the SR8LM, Radical says their car can now match the performance of a LeMans prototype around most circuits.
The Hayabusa based powerplant, which revs to 10,500 rpm, also delivers 250 foot pounds of torque in a compact package. In the SR8LM, it’s matched to a paddle shifted 6 speed transaxle.
source: [ http://thekneeslider.com/archives/2007/07/05/hayabusa-v8-grows-up-28-liter-455bhp/ ]
