TwinTurbo.NET: Nissan 300ZX forum - The transmission (if MT) won't hurt to keep, but I would
Subject The transmission (if MT) won't hurt to keep, but I would
Posted by na300zx (OH) on March 18, 2008 at 5:31 PM
  This message has been viewed 115 times.
In Reply To Question for those who have converted from NA to TT: posted by Viper498 ( MO ) on March 18, 2008 at 05:24 PM
Message go to the TT flywheel and clutch. A guy local to me (kkrofft (OH)) used an NA flywheel w/ a dXd clutch. He had to get the flywheel drilled to accept the clutch he used because noone makes a strong enough clutch in the NA size.
To use the TT flywheel, you will need to grind the inside of the bellhousing a little bit and shim the starter out 2mm.
