TwinTurbo.NET: Nissan 300ZX forum - oil pump ?
oil pump ?
force1
on January 10, 2008 at 5:53 PM
i am replacing my oil pump housing only because i cracked it when i removed my crank shaft sprocket. my ? is there any difference between na/tt oil pumps? and should i buy new or can i pick one up second hand?
thanks
oil pump ? -
force1
17:53:14 01/10/08
I would go new.
nemo1080
18:19:29 01/10/08
the TT oil pump will flow more than an NA.
apudapus
19:00:15 01/10/08
prob be easier for him if he just pulls motor? (n/m)
nemo1080
19:34:29 01/10/08
A search showed that the oil pump can be replaced
ThunderZ
20:36:32 01/10/08
Mmm 30 min to set the jacks maybe :/
zcar4me
21:00:21 01/10/08
I'm not sure how most people can pull the oil pan so easily
TTFairladyZ
23:37:16 01/10/08
2nd.
apudapus
18:17:51 01/11/08
i would do it this way, too (pulling the motor) (n/m)
apudapus
18:18:44 01/11/08
You can not use a NA pump on a TT - they are not the same. (n/m)
19:24:45 01/10/08
can you get a tig welder on it?save lots of work
mossyoak
21:24:36 01/10/08
JB weld (n/m)
AZHeat
21:36:10 01/10/08
2nd. worth a shot. if it works, you saved a ton of
nemo1080
22:05:34 01/10/08
don't think I would risk it on such an important part... (n/m)
Waco300zx(DFW)
09:35:43 01/11/08
im done that before, good luck
Halo Z
23:24:58 01/10/08
lucky for me, the motor is out. i am doing a swap
force1
03:17:27 01/11/08
tell me what not to do, so I dont break mine.
mossyoak
14:20:52 01/11/08
well, first off, be patient
force1
18:03:19 01/11/08
