TwinTurbo.NET: Nissan 300ZX forum - The were rather loose when I did a upper plenum pull and
Zirvana
on April 04, 2007 at 12:18 PM
Interesting. Maybe a good time to do a boost leak check.
posted by Dave N
on April 04, 2007 at 12:11 PM
FI replacement job a few years ago. I intend to check them out again before completing this maintenance project. I probably should do a boost leak test sometime soon (build the device shown by Guapo). Thanks for your comments.
Inspection of original OEM turbos at 264K miles. With the
Zirvana
10:16:25 04/04/07
wow....that's a whole bunch of miles (n/m)
ZXRider(SoCal)
10:18:07 04/04/07
no kidding. compared to that, my 130k is "low miles"
nemo1080
10:22:53 04/04/07
I've got a lot of catching up to do in my NA. 170,000 (n/m)
rufflez
11:20:29 04/04/07
may aswell. thats cool that they still work ok.
nemo1080
10:20:16 04/04/07
Yes, I bought the car as a Dealer Demo with 7,400 miles..
Zirvana
10:24:28 04/04/07
If your car isn't hitting full boost its NOT...
xxbulovax91xx
11:28:14 04/04/07
All I am really doing in replacing my original OEM exhaust
Zirvana
11:47:52 04/04/07
No codes from the ECU with regard to the less than full
Dave N
11:52:14 04/04/07
No ECU error codes. I was concerned about safety boost
Zirvana
12:06:22 04/04/07
Dave N
12:11:25 04/04/07
The were rather loose when I did a upper plenum pull and -
Zirvana
12:18:30 04/04/07
have you checked the stock gauge itself?
inf
13:54:47 04/04/07
Not yet...I know that the stock gauge can be inaccurate.
Zirvana
14:49:44 04/04/07
Don't need an upgraded ECU for exhaust
xxbulovax91xx
12:16:56 04/04/07
What you say is what I've been previously told here on the
Zirvana
12:56:45 04/04/07
I think its still worth changing the oil and water lines.
brahmabull (CT)
10:52:06 04/04/07
if you start changing everything that could go bad at 264k..
AntiHero
10:55:29 04/04/07
Agreed. I will consider replacing water/oil lines only when
Zirvana
11:49:42 04/04/07
Rear main seal.
xxbulovax91xx
11:25:48 04/04/07
New Rear main seal goes in this week. Got chromoly
Zirvana
11:45:29 04/04/07
